Port authorizarion text not recieved - how long does it take?
  • Dec 2, 2022 2:57 AM UTC
  • 666 views
Brian Buchanan
Hello, about 15 min ago I went through the process of trying to port my number from BellMTS and the text I'm meant to say YES to hasn't arrived. How long should this take?
I thought this part should be pretty quick. Not sure what I should do now. Any tips?
Best answer by Dinh
This is strange. Is your BellMTS SIM still working? Can you make/receive call on it?
It looks like it probably worked. Koodo number is active and bell MTS closed the account. Never had to say YES
Well, not sure what happened, but it could be a glitch fr their end.
Brian Buchanan
So I received this:
Koodo Message: Welcome to Koodo. Your transfer request has been completed successfully. Please restart your phone now for the transfer to take effect. Thanks for being a Koodo customer. Free Koodo msg.
Now I'm using the Koodo sim and it worked. However my bellmts yes text never came and my account still shows active there. Will this cause issues? Or is it that BellMTS just automatically approves it? Anyone have a similar experience. Thanks
  • Dec 2, 2022 4:05 AM UTC
Brian Buchanan
  • Dec 2, 2022 4:56 AM UTC
Brian Buchanan
For what it's worth this happened again with a second bellmts number. No YES needed but seems to have worked.
