Phone no showing
  • Jan 16, 2023 11:21 PM UTC
  • 3 replies
  • 126 views
I am looking for a phone no. I called to Fredericton in Dec 22 and it is not there how can I find that no.
  • Jan 16, 2023 11:29 PM UTC
Did you check your Self-Serve account to see which number was dialled? You can also look at the call record on your device.
Did you call with your cell phone?  Did the call connect successfully?
If so you have a few places to find the umber you called.
  1. Check your phone app’s call history log
  2. Login to self serve and review your usage for Minutes
  3. Login to self serve and download your detailed pdf ebill that includes the call history for that day
  • Jan 16, 2023 11:37 PM UTC
Thanks I did all those and now have found my answer
