Parked number
  • Jul 13, 2022 5:51 PM UTC
  • 3 replies
  • 176 views
I have a number parked with a VOIP provider. It can receive text messages. Will that work for assigning it to my new SIM?
Best answer by Dinh
Correct. Voip.ms.
It should be fine, as long VoIP.ms allow it. Here they said you would have to contact them first https://wiki.voip.ms/article/Porting_a_Number
Allan M
  • Jul 14, 2022 12:02 AM UTC
Like you want to port it from your voip provider to Koodo? Which voip provider is it with?
  • Jul 14, 2022 12:27 AM UTC
Correct. Voip.ms.
  • Jul 14, 2022 5:49 AM UTC
Correct. Voip.ms.
