Not finding my address, help
  • May 2, 2026 2:09 PM UTC
  • 4 replies
  • 66 views
I'm trying to change my address through self-serve, but every time I enter my address, the "search" never ends. And if I enter manually, it doesn't find the address, but surrounding ones.
I don't want to have to call 😭  help.
I've been with Koodo for 18 years and I have lived at this address before, so I'm confused why it can't find it.
Thanks
  • May 2, 2026 2:14 PM UTC
I can find my address through Poste Canada so it isn't an issue with them.
  • May 2, 2026 4:43 PM UTC
From your description, it seems there are some scripts that was blocked/ran incorrectly. Could you try to use the incognito mode of the Google Chrome  to see if that can help?
  • May 2, 2026 6:17 PM UTC
That is strange. The address is being verified by Canada Post, so it should have shown up on your Self-Serve account. Let me flag a rep for you.
Rox Koodo
  • May 2, 2026 6:37 PM UTC
Hi there! I’m sorry to hear about that!
Do you remember the address being changed in the past years? Can you try to use a different browser to enter the address and then check if it finds it?
Keep us posted here, please!
