Need Help with Voicemail
  • Apr 11, 2023 2:05 AM UTC
  • 3 replies
  • 430 views
My voicemail is not working. I activated it, but when someone else calls the line, they only get a busy signal. Please help.
Thank you
  • Apr 11, 2023 2:49 AM UTC
It was strange, can you check your voicemail as of now? What do you hear when you dial your own number?
Also, are you a postpaid or prepaid customer?
  • Apr 11, 2023 1:45 PM UTC
Does the call even go through or they receive directly a busy tone?
  • Apr 11, 2023 3:19 PM UTC
Check the voicemail setup guide in the link below to see if any of the steps were missed. If the problem persists, your voicemail service may have to be reset. Keep us posted.
Voicemail | Help
