Minutes usage not showing phone number called in self serve
  • Jun 18, 2023 9:29 AM UTC
  • 484 views
When o log into self serve to check my usage the phone number called for every call is the same but this is not the case. How do I fix this??
Best answer by Dennis
Does the phone number look familiar?
  • Jun 18, 2023 10:01 AM UTC
  • Jun 18, 2023 10:22 AM UTC
Yes, but it’s not the only number I have called or has called me this cycle.
  • Jun 18, 2023 6:50 PM UTC
I saw that in my call history also. The detail call history was messed up. Hopefully they will fix it soon
  • Member
  • Jun 23, 2023 9:12 PM UTC
Same. Hope Koodo fixes the issue
  • Member
  • Jun 24, 2023 10:50 AM UTC
Has anyone found a solution to this?
  • Member
  • Jun 24, 2023 12:45 PM UTC
I have not. The minutes usage issue still continues.
