mesh system
  • Dec 5, 2024 2:50 PM UTC
  • 3 replies
  • 333 views
Is Wi-fi 6 lite router compatible with my Eero mesh router system?
Best answer by Robert T
While bridge mode is a common and effective way to integrate a mesh system with an existing router, it's not the only option. Many mesh systems can work in a standard routing mode, where they handle both the wireless network and the internet connection. However, using bridge mode can simplify the setup and avoid potential conflicts, such as double NAT issues. It's worth checking the specific settings and capabilities of the Koodo routers to ensure compatibility and optimal performance with your chosen mesh system.
  • Dec 5, 2024 3:01 PM UTC
I havden’t checked over the avilable settings on the routers issued by Koodo, but as long as it can be in bridge mode, it should work with any mesh router system.
  • Dec 5, 2024 5:08 PM UTC
Thank you
