Koodo plan for Longterm travel
  • Oct 23, 2026 9:08 PM UTC
  • 4 replies
  • 70 views
Hi, I'm currently outside Canada and want to keep my Canadian phone number active mainly to receive SMS verification codes.
Is there any lower-cost plan available for my existing account?
Best answer by Dennis
Do you have a tab?  If yes you are restricted to Tab plans.
If you have no tab, you may be able to change to a lower plan.  However Koodo tends not to show all plans available in your self serve.  What plan options do you see when you login to your self serve account and try to change your plan
  • Oct 23, 2026 9:26 PM UTC
  • Oct 23, 2026 10:16 PM UTC
I don’t have a Tab right now! I tried to change my plan, but the cheapest one available was 35 dollars! ☹️
  • Oct 23, 2026 11:38 PM UTC
What is your current plan?
  • Oct 24, 2026 12:58 AM UTC
I would suggest you to send a message to a rep on Koodo Expert Messaging and see what they can offer you. They will get back to you within one or two hours. https://Koo.do/Chat
If you are not in a rush, you may want to wait until Black Friday. They generally have some deals, which included the Canada-US-Mexico plan at a lower cost last year.
