just curious
  • Oct 31, 2026 1:12 AM UTC
  • 4 replies
  • 77 views
Purple J
I logged into my koodo acct to see what my bill was and there was a pop up requesting to set up a 2 step verification.  Wanted me to verify my phone number..displaed the last 4 didgets of 2 numbers.  One of which is my number the other was a number I am not sure about. I did, before I went to monthly bill, have a pay as you go phone, with koodo or perhaps telus.  Could the other number be that one? I hadn't used that number in YEARS, to be honest,  I thought once you stopped using pay as you go, the number was deleted.  Ive blocked out the last 4 digits of my number,  but left the last four of the mystery number.  I am assuming its from an old pay as you go phone from the early 2000s
  • Oct 31, 2026 1:57 AM UTC
That is interesting. Is it currently with Koodo? If it has been cancelled, it should not show up on your list. However, it would still be considered an active Koodo number even if it is on a prepaid plan with Koodo. https://www.koodomobile.com/en/help/two-factor-authentication
Purple J
  • Leader
  • Nov 3, 2026 6:58 PM UTC
To be honest...i have no idea.  I recall having a telus prepaid phone in the early to mid 2000s i think....but i am not sure of the exact dates its been a REALLY long time since ive had to think of it. ,...but I've been with koodo since 2011 I don't even recall the prepaid phone number
  • Nov 3, 2026 9:14 PM UTC
The 2nd number would be whatever number you gave to Koodo at that time as Koodo requires a contact number incase something with the application goes wrong.
It could also be the number of a friend or family member or a work number or any number you may have used
Purple J
  • Leader
  • Nov 3, 2026 9:20 PM UTC
I just remembered,  this could be the last 4 digets of an old land line number i had with  bell telephone.  Its been almost 8 years since I had that phone number.  I moved, changed the landline number and now have it through the internet provider.  It's amazing the things that pop into your head when you least expect it. 😆 🤣
