Up north. No cell coverage Can't turn it on
How to turn on Wi-Fi calls without cell coverage
Best answer by Dinh
No, it wasn't set up previously. Is there a chance to switch it on without cell coverage?
No, unfortunately. It needs to be on the cellular network at the time. Also, are you a postpaid customer?
And which device are you using? Some phones aren’t compatible with Koodo Wi-Fi calling..
Login to the community
or
