How do I log out of Self Serve?
  • Apr 21, 2022 3:40 AM UTC
  • 2 replies
  • 964 views
How to log out safely? There is no icon. Nothing under the menu. Nothing under Self serve. I am using the computer not the cellphone.
  • Apr 21, 2022 3:59 AM UTC
You can just close the browserr. But also in self-serve “log out” shows on the top right, beside the language and province selection option.
  • Apr 21, 2022 7:25 AM UTC
I see it under the menu
