how do i get my voicemail? i dont have a ‘mail box number’
  • Nov 13, 2022 2:17 AM UTC
  • 818 views
How do I get a mail box number to retrieve my voicemail?
Sophia
  • Nov 13, 2022 2:22 AM UTC
Have you tried long pressing the number 1 on your keypad?
When do I press #1
  • Nov 13, 2022 2:45 AM UTC
When do I press #1
I think when you would like to check your voicemail. You could do that from your Koodo phone.
Another way to check your voicemail is to dial your own Koodo number from your phone.
  • Nov 13, 2022 12:52 PM UTC
When do I press #1
Like just before making a call you dial the number but instead long press the #1 until it dials the VM number. Some phone have this as a way to call a VM.
  • Nov 13, 2022 6:15 PM UTC
If you’ve recently ported from another provider, restarting your phone may restore the voicemail service. If long-pressing number 1 on your phone’s dial pad does not work, a voicemail access number will have to be added or pushed to your phone. If this is the case, please schedule a callback through Koodo Assist, and a rep will help you get a voicemail access number pushed to your phone.
