help wont open turns black
  • Jan 24, 2023 12:50 AM UTC
  • 14 replies
  • 475 views
I want to speak to Koodo because my phone will not connect to a USA phone number. I called Koodo and the machine told me to start with CHAT, and sent me a text with this link.  When I try to open it nothing happens for a few seconds then Chat flashes on and the screen immediately turns black. Happens again and again. HELP PLEASE
Mayumi
  • Jan 24, 2023 3:41 AM UTC
When you log into your self serve, do you see a pay-per- use International long-distance add-on?
  • Coach
  • Jan 24, 2023 4:18 AM UTC
Yes I do see the pay per use International long distance add on for $0. AND also see the "perk"   $0 International long distance pack
Bernard Koodo
@Yuk Are you able to access it from here?
https://www.koodomobile.com/en/help
Also, I see a few of calls to the US connected earlier today.  Albeit they are very short in duration.
  • Coach
  • Jan 24, 2023 4:45 AM UTC
That link does the same thing . Turns phone screen black.
I made several calls to one US number today. There was no reply and after about 12 seconds it would hang up. I first thought the location had a phone system problem. Then I tried another number in the US.  It was the same...12 second silence then hang up.
Sorry about the red print  in this email. Dont know how I did that!!
  • Jan 24, 2023 4:50 AM UTC
Try resetting your network settings in your phone to see if that fixes the issue.
  • Coach
  • Jan 24, 2023 4:51 AM UTC
Something malfunctioned in the email above. The link you gave me does not work. It goes black also. I made several attempts to call the US today. The phone seemed to connect. Then there was about a 12 second silence and it would hang up. So I tried a second business number and again s 12 second hang up
  • Coach
  • Jan 24, 2023 5:01 AM UTC
Dennis. Does resetting my network settings mean turning things like Airplane Mode on then off again? I fid that sort of thing and still just s black screen for 'help"
  • Jan 24, 2023 5:05 AM UTC
No not airplane mode. You can do a reset to fa for settings for your network settings so that you can see if that fixes your us calling issues.
What is your phone model?
  • Coach
  • Jan 24, 2023 1:42 PM UTC
My phone is motorola gfast
  • Coach
  • Jan 24, 2023 2:08 PM UTC
This morning chat opens properly. So i assume Koodo fixed Chat. Still cant call USA. But have a call back scheduled.
Thank you all for taking time to help me .
  • Jan 24, 2023 3:09 PM UTC
Did it work for you in the past? Was there any error message when you tried to call an US number?
Also, are you a prepaid or postpaid customer?
  • Coach
  • Jan 24, 2023 3:59 PM UTC
Worked in the past. Only message is.. may be long distance charges...then 13 seconds silence then hang up. I pay monthly. Is that  post paid ????.
Just talked to Koodo. He had me try a variety of things...+ Before number...+1....001....01...+1. Nothing worked. Said he would call me back within 24 hours.
  • Jan 25, 2023 2:45 PM UTC
Hi @Yuk
I can see that a ticket has been submitted for investigation, you should hear back from the agent as soon as there is an updated on this.
  • Coach
  • Jan 25, 2023 3:05 PM UTC
Yes thanks Flo. Yesterday I went thru many "try this try thats" and several calls with Koodo. The latest I heard was they now need to work with USA carriers to rectify the problem. Good thring I dont have any urgent need to call the USA. Thanks again
