eSIM is not working for my postpaid
  • July 26, 2026
  • 4 replies
  • 128 views
Hi everyone, I switched from Public Mobile to Koodo for a 5G plan. The migration process required me to get an eSIM. I tried to use my eSIM to SIM adapter but it apparently failed. The number has been transferred to my Koodo account but I don’t have access to that number because eSIM isn’t working.
I purchased this official Koodo Tri SIM card from Telus. Do you think this physical SIM card will work fine with Koodo postpaid 5G? https://www.telus.com/en/mobility/accessories/product/koodo-tri-sim
Best answer by MilkyWay
That should work. If you have access to your Self-Serve account, you can simply update it with the replacement SIM card that you purchased. https://www.koodomobile.com/en/help/koodo-sim-support
  • July 26, 2026
Hi
Just to confirm, did you ever receive the eSIM QR code or welcome email from Koodo? As well, which phone are you using?
On the SIM card itself, a Koodo SIM won't simply work by inserting it, it has to be assigned to your account first. Rather than buying one and hoping it activates, I recommend you go into Self Serve » Mobile Services » Get help with SIM cards and eSIMs, where you can request a replacement SIM card or recover a deleted eSIM. If that doesn't go through, a nearby Koodo store can issue and activate a physical SIM for you, bring your ID.
If you want to retry the eSIM first, the guides are here https://www.koodomobile.com/en/help/esim-on-apple and https://www.koodomobile.com/en/help/esim-on-android
  • July 26, 2026
  • Organizer
  • July 26, 2026
Hi
Hi, thanks. Koodo didn’t send me the QR code. I think users should be allowed to retrieve the QR code from self serve page.
  • July 26, 2026
Hi
At the time of activation, in many cases, customers don’t have access to self-serve yet.
