Detailed mobile internet usage
  • Mar 25, 2023 8:54 PM UTC
  • 4 replies
  • 148 views
With the help of self serve i am able to check how much usage in total done, but what all web traffic i have hit its time duration and amount of data associated with it. How can i check this ?
  • Mar 25, 2023 9:01 PM UTC
Which phone do you have?
Depending on which phone you have, you should be able to check data usage along with which apps consumed the most and least data.
  • Mar 25, 2023 9:51 PM UTC
Google pixel 6 a
i want to check amount of data consumed for a WhatsApp call and when which number
from portal not from phone
  • Mar 25, 2023 10:19 PM UTC
Google pixel 6 a
Koodo does not track apps or itemize that kind of information. They only track the amount of data used.
Keeping track of your data usage
Bernard Koodo
@Sk87 The only thing to add to @rikkster excellent response is the reason….Canadian Privacy regulation protect individuals and in no way any carrier can see what specific sites or apps one is using.
