Cannot login or reset password.
  • Jun 17, 2025 11:53 PM UTC
  • 1 reply
  • 909 views
kiyan49
So when I try to login (PREPAID), I get the invalid user/password message. After that I try the ‘forgot password’ and get the codes, I try to reset password. Then I get this message, even though my password follows all the criteria I get this message.
“The password you entered does not meet the requirements. Please ensure it follows all listed requirements including no use of personal information, common phrases or match your previous password.”
I tried different browsers, and no change.
What should I do?
Best answer by Dennis
Try to register a new prepaid login with a different email
1 reply
  • Jun 18, 2025 1:09 AM UTC
