Can't obtain verification code because email was recently updated
  • April 7, 2026
  • 67 views
Hello Koodo experts -
I created the account on March 31 (new user, prepaid on a plan), and my self serve has correct email, verified at the time and also by logins and correspondence with Koodo.
However - when I wanted to perform a SIM operation in Self Serve I was told that my email can’t be used:
Get verification code
Before we start the transfer, we need to confirm your identity. We’ll send you a 6-digit verifcation code. Where do you want it to go?
<only option is my email>
Result:
This email address can’t be used for verification at this time, because it was recently updated.
Do you know how long it takes for the email address in the account to be considered valid for receiving verification codes?
  • April 7, 2026
Did you change your email at all, or this is what you initially registered with?
If you already have an active prepaid sim, you can use the temporary number signed to your prepaid account too
  • April 7, 2026
This is the same email that I used to open the account 8 days ago, and which I used many times with Koodo just fine. The account and everything work fine, I was just curious how long it takes to accept the email as valid verification method.
  • April 7, 2026
When I talked to a tech (just now) - he said “he never heard about this problem”………
  • April 7, 2026
Hi ​@Cris44
Just to double check, was the rep able to assist with the sim related request?
  • April 7, 2026
Hi ​@Cris44
Yes, that was fixed.
The main and original topic of this message is about not being able to use the email as verification means.
  • April 8, 2026
Hi ​@Cris44
If I recall correctly, there is a 30‑day waiting period before the updated email can be used as a verification method after an email change or activation.
Additionally, their system may flag certain situations —such as using a VPN or accessing the account from outside Canada—as potential security risks, which can also prevent verification
