Can’t change plan due to perk error
  • April 1, 2026
  • 14 replies
  • 126 views
I see others with this problem and I can’t fix it myself. Trying to change my plan in self serve but as soon as I choose a perk(or skip) it gives me an error saying I cannot choose a perk right now. Please help
Best answer by Dinh
Let me flag a rep to look into this. I assume you are using Koodo login credentials to post in the forum?
  • April 1, 2026
habe you tried to change your plan without selecting a perk? After that you can add a perk later. At that point, if it still doesn't work, you can come back here and ask a rep to assist
  • April 1, 2026
Yes I have tried and it still gives the error. Also tried just going into self serve to change/remove perk and it’s the same problem. Tried Koodo assist/chat and they don’t seem to know what’s happening
  • April 1, 2026
  • April 1, 2026
Having exactly the same issue on my end
  • April 1, 2026
  • April 1, 2026
would you be able to help me as well? I am trying to switch to the same plan as the OP stuck and getting the same error.
  • April 1, 2026
Yes I am. Thanks
  • April 1, 2026
No worries, When a rep visit this thread they will see your post and they will check your case as well.
  • April 1, 2026
Hi ​@Kyip87 and ​@winterbee , we’ve sent you a private message to confirm some details. Please check your community inbox when you get the chance, thank you!
  • April 1, 2026
Thank you. Checked and replied.
Andy578
  • April 1, 2026
Tried to switch last night and had the same problem. Now today those same plans that were $30 are showing up at $40. Seems like a bait and switch scheme really. Thinking I might just port out
  • April 1, 2026
Still see the same plans for $30 on my side but still waiting for mod to change me over
  • April 1, 2026
Woke up this morning and pm’d
Andy578
  • April 1, 2026
When I first logged in this morning they showed for a moment then the page showed some error and when I went back they were all $40. Refreshing,  logging out etc all still shows $40. If I try logging in on a different device or browser it again shows $30 for a moment before showing the same error and then showing me $40 plan again.
