Can not swap Sim
  • May 28, 2023 2:48 PM UTC
  • 8 replies
  • 494 views
Liam Henderson
I recently lost my phone. I got a new one, and purchased a new sim card from Koodo to replace it. When I go to swap sim cards online it tries to send me a email verification code to countine. The issue is the email never comes so I cant continue. My email is correct on My Self Serve because I recieved other emails from Koodo. I went to the koodo store and they could not help me. This is very limiting because I do not have access to a phone until this is resolved.
Best answer by Robert T
If you have access to a computer, you can try performing the sim card swap using a different web browser or clearing the cache and cookies of your current browser. Sometimes, technical issues or browser settings can interfere with email delivery.
  • May 28, 2023 4:23 PM UTC
  • May 28, 2023 10:24 PM UTC
Did you report lost and stolen phone in self-serve ? As well, the Koodo store should be able to help. What was the reason that they gave out when you went there?
I assumed your account was active and no suspension?
  • May 29, 2023 2:43 PM UTC
Make sure to check your spam folder
Liam Henderson
This work, I just swapped browsers and received the email, Thanks
Assia B
  • Member
  • May 31, 2023 3:52 PM UTC
Bonjour. J'ai fait le paiement 2 fois de la facture de kodoo 69,51$  par erreur .que faire ?
  • May 31, 2023 4:36 PM UTC
Cela ne vaut pas la peine de faire quoi que ce soit puisque le processus de remboursement chez Koodo prend plusieurs mois. Vous feriez mieux de conserver le trop-perçu sous forme de crédit sur votre compte afin que votre prochaine facture soit inférieure ou à 0 $
  • Member
  • Jun 15, 2023 3:11 PM UTC
Help no way to log in and report stolen phone and need sim swap
  • Jun 15, 2023 4:26 PM UTC
Have you logged into your self serve previously?  How long have you been a customer?
