Adding data not working - I need help!!!
  • May 26, 2026
  • 4 replies
  • 63 views
I used up all my data and I normally get a text where I can add more. This time I cannot and when I went online to self serve I couldnt either. I am only getting a response - Try again later.
How can I call Koodo?
Its been 24 hours and I need data to work!!!
  • May 26, 2026
Hi, Are you a prepaid or postpaid customer?
When you tried to access your self-serve, what was the error message? have you tried to use the “incognito” mode of the web browser to see if that can help?
  • May 26, 2026
Did you already top up your data? If so, it is possible that you cannot add more and additional usage will be subject to a pay-per-use rate. https://www.koodomobile.com/en/help/shock-free-data
Otherwise, you should be able to send a text message to 5337 with keyword 17YES to add a data top-up of 500MB for $21 and 25YES to add a data top-up of 1GB for $29.
  • May 26, 2026
Hi ​@cotedesneige
If you go in self serve under My profile > Mobility > Data Settings > Notifications & blocks > Manage, do you see the option to authorize data unpause? We see that the authorization is disabled at the moment.
Please let us know how it goes.
  • May 26, 2026
When you look at your data usage page in self serve, does it say your data is all used up and paused?
