Account Cancellation Verification
  • Jun 17, 2022 7:27 PM UTC
  • 4 replies
  • 169 views
I had my work transfer my koodo number to my work phone. They use Telus. How do I verify my koodo account has been closed. I could not see in my self serve?
Thanks!
Kathryn
Allan M
  • Jun 17, 2022 7:46 PM UTC
If your number was ported over then it would be closed. A line can’t remain open without a number on it.
What do you see when you login to self serve? You should still have access for a few weeks after you close it.
  • Jun 17, 2022 7:51 PM UTC
Thank you!
I could see the bills, but where I would normally go to “my plan” I could not see?
Allan M
  • Jun 17, 2022 9:44 PM UTC
Thank you!
That would mean it’s cancelled so you’re all good!😊
  • Jun 18, 2022 12:15 AM UTC
Thanks 🙏
