POCO X5 Pro 5G Compatibility
  • Jul 19, 2023 7:14 PM UTC
  • 4 replies
  • 426 views
POCO X5 Pro 5G
Are these bands compatible with Koodo, excluding 5G? Please advise.
5G+5G
5G: n1/3/5/7/8/20/28/38/40/41/77/78
4G: LTE FDD: Band 1/2/3/4/5/7/8/20/28/66(60MHz)
4G: LTE TDD: Band 38/40/41
3G: WCDMA: Band 1/2/4/5/8
2G: GSM: 850/900/1800/1900MHz
Best answer by Allan M
This is your 3rd one of these today. Let me restructure my answer for you that will be a little more helpful for future phones!
Here are the frequencies/bands that Koodo primarily uses:
2G: None
3G: 850Mhz (B5), 1900Mhz (B2) - (Both used for 4G in some regions as well)
4G/LTE: 1700/2100Mhz (B4), 700Mhz (B12/13/17/29), 2600Mhz (B7)
5G: None
Allan M
  • Jul 19, 2023 7:50 PM UTC
2G: None
5G: None
  • Jul 19, 2023 7:53 PM UTC
Yes, this device is compatible with Koodo’s 3G and 4G LTE-FDD networks. Koodo does not operate a 2G network. 3G and 4G share Bands 5 and 2 (or 850MHz & 1900 MHz).
Edit: I didn’t see Allan_M’s post until I refreshed the page.
  • Jul 19, 2023 8:02 PM UTC
Thanks, apologies for the multiple requests, looking at options for a new phone.
Allan does the, 'B' in your (B4) mean Band?
Allan M
  • Jul 19, 2023 8:19 PM UTC
Oh 100% okay to ask multiple questions. Just figured that I would restructure my answer so that you didn’t have to ask and then wait for an answer every time!
And yes, the B would be short for Band.
