Pixel 10 Pro Fold Restock info
  • July 27, 2026
  • 3 replies
  • 82 views
I have been looking to get the Pixel 10 Pro Fold but it went out of stock and then has disappeared from the Koodo page. It remains on the Telus page and since then the Google Store has had it come back in stock. I was wondering if anyone knew if Koodo would be getting it back. The 11 Pro Fold is still not out til October. I so very much wish the Motorola Razr Fold wasn’t a Rogers exclusive - it’s the one I really want but I’m not going to Rogers/Fido.
Sophia
  • July 27, 2026
It’s hard to say whether it will come back in stock, Koodo doesn’t really announce in advance whether a phone will be back in stock or not. Alternatively you could check some stores around you if they happen to have one in stock… or otherwise you could consider buying it directly from the Google store and get a BYOD plan :)
  • July 27, 2026
It is not a best-selling phone, so it is unlikely that it will be restocked on the Koodo page. However, you can reach out to your nearest big-box retailer such as Best Buy and ask them if the Pixel 10 Pro Fold is in stock. If it is available, you should be able to upgrade your device on a Tab plan.
  • July 29, 2026
Are you able to save up to buy the Razr Fold?
If so, I would do that and purchase straight from Motorola
https://www.motorola.com/ca/en/p/phones/razr/motorola-razr-fold/pmipmjj43my?gclsrc=aw.ds&gad_source=1&gad_campaignid=1827129765&gbraid=0AAAAADqrZ8wLQH5jsjiLadfH-sNqeZ8E5&gclid=CjwKCAjwyabTBhBFEiwAM3mNUM9y65_Hfm5UG6lkHEaS0T60SGzJ8sutnWYQR6eZK5A-CdXZ-zza9BoCIyMQAvD_BwE&pn=PBAY0001CA
