Phone upgrade, stuck in a loop
  • 2 replies
I’m trying to upgrade my phone on my existing number.  I have a phone selected, and it keeps rotating me between “your order so far”, and the only option is to “select a plan”, then i go with “keep my existing plan”, but it sends me right back to “your order so far”, where the only option is to go back to “select a plan”.
How do I actually purchase this phone?
Best answer by Goran
Let me flag a rep to assist if you’re continuing to get a 4001 error.
Did this help you find an answer to your question?
  • 29062 replies
  • March 20, 2025
Are you getting the phone on tab?  Is it a Tab plus or Tab basic?
What is the cost of your current plan?
  • 17364 replies
  • March 20, 2025
If you saw the message, it appears your current plan isn’t eligible to upgrade. You would need to select a new plan if you would like to do that with self-serve.
  • 13572 replies
  • March 20, 2025
You should confirm that the price of your plan meets the minimum plan price requirements of the tabs.
  • 2 replies
  • March 20, 2025
Hello, I tried going through with selecting a different plan which is similar but not identical to what I currently have, and was able to get all the way to the purchase screen.  However once I enter my credit card information and hit purchase, it gives me the following error.  I've done this several times, using a different credit card, using a different browser, using a different browser after clearing cache, all with the same result.
Oops! Something went wrong.
Our systems aren't able to process your transaction at this time. Please try again later.
Getting tokenization error. ERROR CODE - 4001
  • 13572 replies
  • March 20, 2025
  • 6176 replies
  • March 20, 2025
Did you try using a different device?
  • 2 replies
  • March 20, 2025
I did, I tried on my laptop and the same result.  It makes no sense at all.
Darius Koodo
  • 1158 replies
  • March 20, 2025
Hi there ​@akak
Sorry to hear that you are experiencing difficulties with the website. Our team is currently looking into this.
I’m experiencing the same issue trying to upgrade Error Code 4001 tried on laptop and phone different cards stuck in the loop.
  • Member
  • 2 replies
  • March 21, 2025
Also having same issue
  • Coach
  • 9 replies
  • March 21, 2025
Also having that issue, and now you can only pay retail price for phones and no tab option when looking to upgrade your phone.
Been 3 days, even talked to a rep and they couldn't explain just kept transferring me.
  • Member
  • 2 replies
  • March 22, 2025
Darius Koodo wrote:
Hi there ​@akak
Any news on this error? I need to change my phone asap
  • 5960 replies
  • March 22, 2025
Hi ​@Sob Unfortunately, we don’t have yet an update, however  the issue is being investigated.
We have sent you a PM so we can confirm some more details, please check your community inbox when you get the chance.
  • 5960 replies
  • March 22, 2025
@akak ​@MichealWozniak  We see that you got in touch with a rep in the meantime, please let us know if you need further help with the order.
@Vicki86 We’ve sent you a PM, please check your community inbox.
  • Member
  • 1 reply
  • March 24, 2025
Any luck so far? , been having the same problem the last few days trying to get a s25
  • 5960 replies
  • March 24, 2025
Hi ​@Ghosty
Sadly, we don’t have an ETR, however the team is putting all efforts to fix the issue,
We have sent you a PM so we can confirm some more detais, please check your community inbox when you get the chance.
