Phone Charger
  • Dec 22, 2021 2:25 PM UTC
  • 4 replies
  • 516 views
BalsamLaker
I haven’t owned a cel phone in 30 years. Does a charger come with the iphone 12 ?
Best answer by Dinh
Unfortunately,No.
In fact. None of the iPhone from Apple have a charger, as of now.
  • Dec 22, 2021 2:35 PM UTC
Unfortunately,No.
Allan M
  • Dec 22, 2021 2:37 PM UTC
It comes with a charging cord but not the wall adapter.
The apple branded ones are $25 to buy although you can find cheaper alternatives kicking around as well.
BalsamLaker
  • Dec 22, 2021 3:25 PM UTC
Thanks for the help ! Much appreciated.
  • Dec 22, 2021 7:32 PM UTC
If buying an off-brand wall adapter, make sure it has a minimum of 20 watts output or your iPhone 12 will take forever to charge. I’ve tested the wall adapter in the link below and it works perfectly on an iPhone 12 Pro.
Anker USB C Charger 20W
