Need help ordering a new phone
  • May 24, 2022 12:53 AM UTC
  • 2 replies
  • 226 views
Hello there from Canada. I have 2 phone numbers associated with my account and not me but the other number needs to order a new phone his is not working very well. How do i go about this as i want to just make payments per month on it and not change my plan and stuff . Can this be done?. And how does one go about it ?,  Also we both have our own phone #,s but it is originally my account i added him and his number after the fact . Hope someone can help and thanks in advance .
Allan M
  • May 24, 2022 1:13 AM UTC
Choose the phone you would like from the link below, click add to cart, select the number you’d like the phone for, and then follow the prompts for the checkout.
You may be required to change your plan depending on your current one. It’ll let you know if you have to change it or not.
https://www.koodomobile.com/phones
  • May 24, 2022 3:19 AM UTC
Thanks Alan ya I figured it out. My plan had to be changed as well to get the tab. So I purchased a phone and it waiting for approval.  Thanks again for helping much appreciated.
