how do I get a hold of a koodoo actual person
  • August 22, 2026
  • 3 replies
  • 125 views
I have been trying to find a number for over 2 hours to speak with a rep. I have gone through the chat thing. Super frustrated. I have a black screen so am not even able to make calls and want to order a new phone but want to also add a line. I am wanting to talk to an agent which seems mission impossible. I am wondering if my best bet is to go to Costco and start from scratch. I have been with Koodoo for at least 15 years but this is ridiculous. Any suggestions
  • August 22, 2026
Hi,
Both of those you can actually do yourself in Self Serve, ordering the new phone and adding a line. The catch with a black screen is the SMS verification code, both flows send one and you have to be able to read it. If you still have the SIM, put it in another phone to get the code.
For a callback, go to www.koodo.com/chat and type what you want (e.g. "I want to add a line") and the system calls you back, but it has to be a Canadian number that can receive incoming calls, so that won't work if your only phone is dead. https://m.me/Koodo is another way to reach a rep.
With a dead screen I would also recommend a Koodo store, they can do the new phone and the extra line at the same time.
  • Rockstar
  • August 22, 2026
thank you, I’ll try those links. I’ve been trying the chat but it won’t let me sign in. I’m borrowing someones phone and not the best at technology so it might be easier to reach out to a different provider that I can actually speak with someone. I will try those links you sent to see if I have any luck. Thanks again
  • August 23, 2026
Since you are unable to use your phone, the easiest way is to head to your nearest Koodo store or third-party retailer such as Best Buy or Walmart to assist you.
