having my own router will make my plan cheaper
  • Jul 3, 2025 10:19 PM UTC
  • 1 reply
  • 449 views
Hello, I was wondering if having my own router will make my plan cheaper?
Best answer by Oliver C
No, the price for the Internet subscription stays the same if you use your own equipment. The equipment is complementary to the service. You would only pay for the equipment if you fail to return it if you were to cancel the subscription.
1 reply
  • Jul 3, 2025 10:33 PM UTC
