Buying and keeping a phone
  • Nov 19, 2022 5:19 PM UTC
  • 2 replies
  • 149 views
renatam
If I buy a phone with a plan, should I return the phone after 2 years or do I get to keep it?
Best answer by Mayumi
You will keep it and can continue to use it until it break 👍
Mayumi
  • Nov 19, 2022 5:22 PM UTC
  • Nov 19, 2022 5:23 PM UTC
You keep it. it is yours from the date you purchased.
