Buying a phone and phone plan without credit card info.
  • Jan 3, 2022 8:10 PM UTC
  • 1 reply
  • 1987 views
Hi,
I made a credit card and it is on process now, so I don't know CVV and expiry date yet(only can check card number on my banking app). I really want to buy a phone and phone plan promotion before Jan 4th (promo end). Is there any way to do this?
I talked with an agent from my bank, but they didn’t allow me to have those info over the phone, because it is dangerous.
Best answer by Dinh
If you are buying online, you need a credit card (with full information)  AND you would need to pass their credit check to get a phone.
If you don’t have a credit card available, you can try to get it at a store and bring other ID with you https://www.koodomobile.com/en/help/credit-check-requirements
1 reply
  • Jan 3, 2022 8:14 PM UTC
