Introducing the Moto G Power
  • May 19, 2022 5:45 PM UTC
  • 0 replies
  • 130 views
Chris Koodo
The Moto G Power is now available for Koodo customers. When you're looking for ways to stay connected to all your favourite people or telling your story in more creative ways. Explore what’s possible with Moto G Power!
Key features
  • Up to 3-day battery (5000 mAh)
  • 50 MP camera system + Dual Capture
  • 64 GB built-in storage
  • 6.5" HD+ display with 90 Hz refresh rate
  • Octa-core performance
  • Water-repellent design
  • Fingerprint reader and face recognition
Note: All battery life claims are approximate and based on average mixed use under optimal network conditions in a lab setting. Actual battery performance will vary.
Detailed Specifications
Network
Technology
GSM / HSPA / LTE
2G bands
GSM 850 / 900 / 1800 / 1900
3G bands
HSPA 850 / 900 / 1700 / 1900 / 2100
4G bands
LTE B1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 25, 26, 38, 41, 66, 71
Body
Dimensions
167.2 x 76.5 x 9.4 mm (6.58 x 3.01 x 0.37 in)
Weight
203g
Build
Glass front, plastic back, plastic frame, IP52 water repellent design
SIM
Nano-SIM
Color
Dark Groove Black
Display
Type
IPS LCD, 90Hz
Size
6.5 inches (~79.7% screen-to-body ratio)
Resolution
720 x 1600 pixels, 20:9 ratio (~270 ppi density)
Platform
OS
Android 11
Chipset
MediaTek Helio G37
CPU
Octa-core
Memory
Card slot
microSDXC (up to 512GB)
Internal
64GB Storage, 4GB RAM
Rear Camera
Quad
  • 50MP sensor, 1.3µm (Quad Pixel) f/1.8
  • 2MP macro, 1.75µm f/2.4
  • 2MP depth 1.75µm f/2.4
Features
LED flash, HDR
Video
1080p@30fps
Front Camera
Single
8 MP, f/2.0, 1.12µm
Video
1080p@30fps
Audio
Loudspeaker
Yes
3.5mm jack
Yes
Connectivity
WLAN
Wi-Fi 802.11 a/b/g/n/ac 2.4G+5GHz, dual-band, Wi-Fi Direct, hotspot
Bluetooth
5.0, A2DP, LE
GPS
Yes, with A-GPS, GLONASS, GALILEO
NFC
No
USB
USB Type-C (2.0)
Features
Sensors
Fingerprint (side-mounted), accelerometer, gyroscope, proximity, e-compass, barometer, ambient light sensor
Battery
Type
Li-Po 5000 mAh, non-removable
Charging
Fast charging 10W
