top up voucher pin ?
  • Feb 3, 2022 7:18 PM UTC
  • 1 reply
  • 499 views
Ryan Antoine
I’m I bought a 50$ top up card from metro an. I have my code. ####045*******20## but it says I need the pin what’s the pin code if the one I got isn’t it no where on the paper does it show a pin code just the long one
Best answer by Allan M
If that's your topup code I wouldn't post it here as it's a public forum.
If you wish to add that to your account you just need to dial 611 and then press option 1, and then option 1 again if i remember correctly.
It should only prompt you for your pin if you're making account changes, not for top ups.
If you are also wanting to make account changes or just figure out your pin, it would be a 4 code that you made when you first created your account.
1 reply
Allan M
  • Feb 3, 2022 7:55 PM UTC
