switch from Post paid to Prepaid
  • Nov 17, 2026 2:01 AM UTC
  • 3 replies
  • 50 views
I need help or call back to switch my connection from Post to Prepaid.
Please reach out to me.
  • Organizer
  • Nov 17, 2026 2:05 AM UTC
I'm trying to switch from a postpaid plan to a prepaid one. I selected transfer existing phone, but it does not give koodo as an option so I cannot proceed beyond this. The Q&A section has a link, but that just brings you to the home page. What do I need to do to transfer the number?
  • Nov 17, 2026 2:23 AM UTC
It is an entirely separate process.
You will need to get a physical SIM card or order an eSIM on the portal while setting up your Self-Serve account to initiate the porting process. https://www.koodomobile.com/en/help/activating-your-prepaid-account
Once you activate your service with Koodo Prepaid, you should be able to port over your number from Koodo Postpaid. https://www.koodomobile.com/en/help/moving-your-number-koodo
  • Nov 17, 2026 2:30 AM UTC
Koodo won't show up as an option at that step. What I would do is activate the prepaid SIM with a new number first. After the prepaid activation completes, log in to prepaid Self Serve, go to Profile and select Change phone number to port your number over from your Koodo postpaid https://www.koodomobile.com/en/help/koodo-prepaid-self-serve-faqs
Once the porting is done, your postpaid account would be closed. You can wait for the final postpaid invoice in Self Serve and pay or receive credits from it. If you switch mid billing cycle, credits applied in advance on your last bill (like the autopay discount) get removed on that final bill https://www.koodomobile.com/en/help/things-know-about-cancelling-koodo
