Phone showing old number after porting
  • September 29, 2026
  • 7 replies
  • 78 views
I ported my phone number from Public Mobile to Koodo Prepaid (I got a call back via chat and had an agent do it over the phone as I was told to) but when I look at the settings app in my phone under SIM or about phone it’s still showing the temporary number I was assigned before I ported my other number over.
Did you restart your phone after the port transfer? Are you able to use another phone to make a call to your number and see if it rings?
Does it make and talk calls with the ported in number?  What do caller ID’s say?
How about texts?
  • September 30, 2026
Yes I restarted. It receives calls and texts OK (not sure about outgoing caller ID). But I even tried a different phone and it shows the temp number still.
Let me flag a rep for you. They may need to provision your line.
I suggest calling the porting team
1-844-232-7678
Hi ​@curtis93
Unfortunately, we have limited access here on the community when it comes to Prepaid Plans, however, if the issue still persists, we recommend scheduling a call back with the virtual assist or calling the phone number indicated by Dennis above.
Since you are on a prepaid plan, you will need to schedule a callback through Koodo Assist to provision your line. https://widget.telus.tiia.ai/koodoprepaid/koodoprepaid.html
