Need help switching newly activated Prepaid line to Postpaid while outside Canada
  • August 11, 2026
  • 83 views
Dear Koodo Team,
I just purchased and activated a Koodo Prepaid eSIM, but after activation I learned that Koodo Prepaid service is not available outside Canada and the U.S. I am currently outside Canada, so the line shows No Service and I cannot receive calls or SMS.
My Prepaid account number is 1000000****6. I can provide the full account number privately to a Koodo representative if needed.
I would like to switch this new Prepaid line to a Koodo Postpaid plan so I can use the number while abroad.
I found information about the Fast Switch Self Serve option for moving from Prepaid to Postpaid, but I am currently unable to access my Prepaid Self Serve account.
The first issue is that the login process requires an OTP sent to my Koodo number. Since the Prepaid line cannot connect to a network where I am, I cannot receive the OTP.
I also tried using Forgot Password and resetting the password through email. However, the password reset does not work either.
The page says that the password must:
  1. Contain a minimum of 8 characters
  2. Include at least one uppercase letter
  3. Include at least one lowercase letter
  4. Include at least one number
  5. Include at least one special character
  6. Contain no spaces
  7. Match in both password fields
  8. Not contain more than 2 identical letters or numbers in succession, for example AAA or 111
It also says the password will not be accepted if it:
  1. Contains personal information such as first name, last name, or email
  2. Uses common password phrases, for example P@ssword
  3. Matches the previous password
I have tried multiple passwords that satisfy all of the listed requirements and avoid all of the prohibited conditions, but I still receive this error:
“The password you entered does not meet the requirements. Please ensure it follows all listed requirements including no use of personal information, common phrases or match your previous password.”
So at the moment I am blocked in two separate ways:
  1. I cannot receive the SMS OTP because the Prepaid line has no service outside Canada/U.S.
  2. I cannot regain access through the email password-reset process because passwords that appear to satisfy all published requirements are still being rejected.
Could someone please advise how I can switch from Prepaid to Postpaid in this situation, or how Koodo Support can manually assist with the Fast Switch process?
Ideally, I would like to:
  • keep my existing Koodo phone number;
  • transfer any eligible Prepaid balance/value to the Postpaid account;
  • complete the switch without needing to receive an SMS OTP on the currently unavailable Prepaid line;
  • regain access to Self Serve if that is required for the migration.
The Prepaid account and eSIM were purchased yesteraday and have not been usable from my current location.
Many thanks!
  • August 11, 2026
How dd you sign up for the prepaid account?  Did you select and pay for your base plan?
Is this a new number or did you port a number in?
  • August 11, 2026
Hi
Koodo prepaid only works in Canada and the US, so the line will keep showing No Service where you are, and prepaid Self Serve and the OTPs are restricted outside the country. That's why the password reset isn't going through either, it isn't the password itself.
Don't delete the eSIM, a deleted one can't be recovered.
For the switch to postpaid you'd need a prepaid rep, community reps can't access prepaid accounts. They're reachable through the prepaid chat portal www.koodo.com/prepaidchat. Since a callback can't reach your Koodo number, I would have a friend or family member in Canada take the callback on your behalf, or set up a Canadian VoIP number they can reach you on.
  • August 11, 2026
Thank you, Dennis. I signed up online directly from Germany, selected and paid for the 365-day prepaid base plan, and activated the eSIM.
This is a completely new Koodo number. I did not port an existing number in.
  • August 11, 2026
Hi
Thank you, Dinh. I appreciate the explanation and the suggestion.
Unfortunately, I have not been able to get to the callback pathway. When I try to access the prepaid support/Self Serve flow, I appear to need to log in to my Prepaid Self Serve account, which I cannot currently do for the reasons described in my post: I cannot receive the OTP, and the email password-reset process is also rejecting passwords that meet the stated requirements.
Is there a way to reach a prepaid representative or request a callback without first being able to log in to Self Serve (e.g., via email)?
  • August 11, 2026
Because you are overseas it is near impossible to confirm your prepaid account to move over to postpaid.
If you have access to a Canadian number you can request a callback via Koodo assist and then select prepaid.  Then ask to schedule a callback.  But i wouldn't be too optimistic.
Note that prepaid is also technically no refunds.
If you still want a postpaid plan, you can sign up for koodo postpaid.  Note that if you are overseas, you may run into issues and may need a VPN to show you are in Canada (this has been hit or miss in the past).
  • August 12, 2026
Since you are currently not in Canada, you may need to download an app that can make or receive calls from Canada, such as Fongo, and schedule a callback through Koodo Assist to that number to speak with a rep. https://widget.telus.tiia.ai/koodoprepaid/koodoprepaid.html
