Monthly plan to prepaid plan
  • Apr 30, 2022 5:40 PM UTC
  • 2032 views
Hi
I want to switch from monthly plan to a prepaid plan. Will I be able to do it through Self service? Ordo I need to contact a Koodo rep to do so?
Thanks!
Best answer by Sophia
Neither. All you need to do is purchase a prepaid SIM card and set up your account online with a random number. Then when it's done, you can port in your postpaid number and the account will close automatically.
  • Apr 30, 2022 5:44 PM UTC
You can port over via self serve. You'll set up your prepaid first and then you should transfer your number in prepaid self serve. You'll have to pay for whatever tab is left if you have one of course and get a final bill that you can accèss in self serve for up to 90 days after you port.
  • Apr 30, 2022 5:59 PM UTC
Hi Goran,
Thanks for the reply.  So, in order to setup my prepaid plan first, I will need to talk to a rep or visit one of the Koodo booth first?
Sophia
  • Apr 30, 2022 6:19 PM UTC
  • Apr 30, 2022 7:02 PM UTC
Hi Sophia,
Thanks for the clarification.  Once I ported my number to prepaid, will my current monthly plan stop automatically?
Sophia
  • Apr 30, 2022 7:04 PM UTC
Yes, absolutely. Your number can only be active with one account, so as soon as you port it over to prepaid, your postpaid account will automatically be terminated. You don’t have to involve a rep at all.
