do I loose prepaid booster minutes
  • Aug 16, 2021 12:37 AM UTC
  • 1 reply
  • 118 views
i lost my phone .if i buy new sim card, do i loose my prepaid minutes /
Best answer by Dinh
No, you can keep the number and booster. All you need to do is swapping SIM.
if you lost the SIM card, you can get a new prepaid Koodo SIM from a Koodo location. After that follow this to swap the SIM to the new one https://www.koodomobile.com/en/help/prepaid-sim-cards
1 reply
  • Aug 16, 2021 12:44 AM UTC
