Data Remaining doesn't match usage, plus other errors
  • Oct 21, 2026 11:04 PM UTC
  • 4 replies
  • 30 views
I am on the prepaid service.  My overview page shows 6.27 GB of usage this period (last night it showed 6.37 GB ?) but when I go through the usage history and manually add up all the entries, it only comes to just over 2 GB of usage.  (I did that after getting texts warning I used 10 and then 20 percent of my data and that was surprising to me.)  I requested a callback and started speaking to someone who implied it would be too time consuming for them to add up my history to check what I was saying and then somehow the call cut out and they never called back.  I don’t know what to do.
In addition, I have phantom calls to voicemail many days and I have one or 2 small data charges each evening for no apparent reason.  I already used this forum to follow tips like turning off wifi assist and background app refresh, etc and nothing made a difference so I have cellular fully off but I am still getting these nightly data charges!
How do I get help with this?  I just want to have access to the data that I paid for.
  • Oct 21, 2026 11:10 PM UTC
What phone are you using?
  • Oct 21, 2026 11:38 PM UTC
It’s an iPhone 12.
  • Oct 22, 2026 12:03 AM UTC
iPhones dont have the best data tracking feature.  I suggest getting a 3rd party data tracking app to see if the usage on your phone lines up with what Koodo is reporting
Regarding the phantom voicemail, did you happen to receive a call during that time that went to voicemail?
  • Oct 22, 2026 5:39 AM UTC
Thanks, I’ll look into tracking apps.   Any idea why the total data usage on the overview page of my account (self-service) doesn’t match the total of the individual history entries when you add them all up?  I had 2 other people check the numbers in the spreadsheet and we all got to the same number.   My partner also has a Koodo prepaid phone and his history matches the total on the main page, so it seems really strange that my total is off and by so much (4 GB difference between actual usage reported in history and the total showing, which I know isn’t a lot to some people but I’m on a 30 GB annual plan and I use so little data, so 4 GB is a big difference to me).
As for the voicemail calls, I haven't received a call on my phone in several weeks, but these voicemail entries pop up every few days (and I’m not calling into voicemail).  I also don’t get any notifications saying I got any voicemails.
And otherwise, do you have any tips on getting help from Koodo?  The Koodo Expert feature isn’t open to prepaid customers, Koodo Assist was beyond laughable, the Call back employee wasn’t helpful, and it seems there isn’t any other way to reach a customer service agent?  (?email? phone?)
