Data booster purchased but not showing
  • Jul 21, 2021 5:29 PM UTC
  • 3 replies
  • 292 views
Two days ago I purchased a 300-minute long-distance talk booster add-on AND a 1 GB data booster add-on.  My Visa card has been charged for both.  The long-distance talk booster is showing but not the data booster. Why? Will the data booster show up later?
Best answer by BobTheElectrician
Golden rule for boosters: add money to your account first, then purchase what you want. I’ve been sent thru a loop when trying to do it the other way ‘round when the system prompts you to top up.
  • Jul 21, 2021 5:31 PM UTC
It should show up on your prepaid Self-Serve account. I would suggest you to contact a Koodo rep. Either schedule a callback through Koodo Assist or send a message on Facebook Messenger or Twitter.
  • Jul 21, 2021 6:45 PM UTC
It is a 2 step process in that you first add funds and then you buy the booster.
Double check your account and if you still have the amount of the booster purchase as a credit, then the 2nd step was not done.  You can just continue on and make the purchase to complete.
BobTheElectrician
