Changing PIN on prepaid Account
  • Apr 22, 2022 12:05 AM UTC
  • 2837 views
I just got a prepaid account activated.  I selected my PIN during this setup process.
Now - I want to change my PIN because I had to give it to the Koodo CS rep during a call.
How do I change my PIN ?  (Note:  this is the PIN for accessing my account when dialing *611)
Thanks
Best answer by BobTheElectrician
There’s no option to change your PIN online, but DO go into self-serve, click on Change Security Question and make note of your current answers. You will have to contact Koodo and the rep will probably grill you on those questions.
  • Apr 22, 2022 12:08 AM UTC
Thanks
You should be able to change it on your Self-Serve account. Have you tried logging in and see if the option is available?
  • Rockstar
  • Apr 22, 2022 12:45 AM UTC
Yes - I’ve looked on Self-Serve and couldn’t find anything.  And there’s nothing really posted on the help articles and community chats.
Sophia
  • Apr 22, 2022 1:01 AM UTC
You know, I’m a bit rusty with prepaid now, but I believe you will need to contact Koodo to change your PIN - I know you do with Public Mobile. You can actually ask the rep to change it for you during a call, and they’ll try to verify your account by asking questions only you could answer. Then they should give you the ability to pick a new one.
Paging @BobTheElectrician the prepaid king to verify if what I just said is true :)
BobTheElectrician
  • Rockstar
  • Apr 22, 2022 2:28 PM UTC
Thanks BobTheElectrician and Sophia.  Much appreciate the quick replies.
