base plan
  • May 30, 2022 11:58 PM UTC
  • 3 replies
  • 147 views
Ted B Morris
My 100min base plan has used all it’s minutes. Does it begin to use the Booster Add-On minutes for Canada Wide Calling or is the phone locked until I ‘top up’.
Sophia
  • May 31, 2022 12:13 AM UTC
If you have a talk booster, when you call or get called, it will start using those minutes. Whatever you don’t use, will remain until the next time you need extra minutes.
Ted B Morris
  • May 31, 2022 12:36 AM UTC
I thought the logic was to begin to use Booster Add-Ons also, but my phone gets locked until I ‘top-up’ ?
I have plenty of ‘Add-On’ minutes
Sophia
  • May 31, 2022 12:53 AM UTC
Are you saying that your plan is suspended right now? In that case you will have to top up to renew your base plan in order to be able to use your boosters.
But if your base plan is active, and if you have plenty of add-on minutes. you’re good to go. What is your base plan renewal date?
