why does easy roam say "active" in self serve section when airplane mode is on and data is off
  • Sep 26, 2024 5:23 PM UTC
  • 3 replies
  • 132 views
I have not activated it and better not be charged for it
Best answer by Allan M
Are you referring to this section?
If so, it just means that Easy Roam is properly setup on your account to be used if you need/use it in the future.
  • Sep 26, 2024 7:19 PM UTC
Where does it say active?
When did you turn on airplane mode? And when did you leave Canada?
Allan M
  • Sep 26, 2024 7:46 PM UTC
Yes thats it. ok thanks that clarifies it. Apprrciate it
