When Using Easy Roam
  • Jul 30, 2022 5:41 PM UTC
  • 1 reply
  • 127 views
I have an iPhone. When using “Easy Roam” should I turn on roaming in my settings → Cellular → Cellular Data Options → Data Roaming On/Off?
1 reply
  • Jul 30, 2022 7:03 PM UTC
Hi @AJ42468
If you need to use data in roaming, data roaming should be turned on.
Otherwise, you should still be able to make/ receive calls and send/ receive text messages, as long as pay per use roaming add ons are provisioned to your services (when travelling out of US).
More about Easy Roam and roaming services you can find here: https://www.koodomobile.com/en/help/easy-roam
