Using Data on EasyRoam
  • Jun 23, 2025 6:32 PM UTC
  • 1 reply
  • 173 views
I am going to be travelling to Ireland for a week, and then England for another week. I am planning to activate EasyRoam so that I can use my current number for calls/texts. I need my phone number for business purposes so I chose to use this over an eSIM.
Am I able to use my regular data plan as well to use the internet while I am abroad, or will it only be for calls and texts?
Best answer by Flo Koodo
With the Easy Roam travel pass, you can use the data from your plan, call and text phone numbers in the country you roam and Canada.
Calls made to another country other than Canada and the country you roam will be charged roaming pay per use.
More info here https://www.koodomobile.com/en/help/easy-roam
1 reply
  • Jun 23, 2025 6:41 PM UTC
