US Roaming Pay Per Use SMS
  • Feb 18, 2022 2:10 AM UTC
  • 3 replies
  • 346 views
jcornelsen1
I’m going to the US for 3 days. May only need to use SMS. The pay-per-use rate is listed as $10 per 100 outgoing texts. Does this mean I pay $10 no matter what and can send up to 100 texts?
In other words, if I only sent two texts, do I still pay $10? If this is the case, Easy Roam is obviously the way to go.
Thanks!
Allan M
  • Feb 18, 2022 2:30 AM UTC
Correct. You can think of it as the 1st text costs $10 and then you get 99 free.
If you're only going to send a few texts, go this way, otherwise easy roam at the $9-$11/day is the better bet.
jcornelsen1
  • Feb 18, 2022 2:34 AM UTC
Thanks - for some reason it got in my head that it would be $10 per day with up to 100 texts in that day. But makes sense that it would apply to the whole trip.
  • Feb 18, 2022 3:17 AM UTC
Also make sure that if you want to use PPU rates, you need to deactivate easy-roam.
