unlimited minutes and unlimited AIR MINs
  • Dec 30, 2022 4:45 PM UTC
  • 1 reply
  • 315 views
Hello
I have two adds on which seems they are the same. But I pay for both:
  • $5 Unlimited AIR Mins
  • $2 for unlimited minutes
I would like to confirm If I cancel the first one, I will still have the unlimited long distance incoming and out coming call.
Thanks
Best answer by Bernard Koodo
@Meisam That is correct. You can remove the $5 one and “still have the unlimited long distance incoming and out coming calls” within Canada.
1 reply
Bernard Koodo
  • Dec 30, 2022 5:27 PM UTC
