unlimited call plan to US
  • Mar 22, 2022 3:57 AM UTC
  • 1 reply
  • 343 views
Please is US included on the unlimited calls to Canada? this is coming as US/Canada uses the same plus 1 dialing code.
Best answer by MilkyWay
No, you will need to pay long-distance charges making calls to the U.S. from Canada. It is $0.80 per minute, which can become a hefty charge once you keep using the minutes.
If you make occasional calls to the U.S., you can consider the International Long Distance Saver add-on for $5 per month, lowering your rate to $0.05 per minute. For unlimited calls to the U.S., I would suggest you to look into the add-on for an extra $15 per month. https://www.koodomobile.com/en/help/long-distance-calling
1 reply
  • Mar 22, 2022 4:26 AM UTC
