Travel Pass for Europe, do I need to activate roaming??
  • Jul 30, 2025 1:55 PM UTC
  • 2 replies
  • 693 views
Eva Schunicht
The titel says it all… thank you! :-)
Best answer by Flo Koodo
Hi ​@Eva Schunicht
You will need the add ons International Voice Roaming and International Data roaming, in order to be able to use the services in roaming.
Also, if you have Easy Roam Intl and the Europe travel pass, you will be charged only the travel pass fee once you start using the service in the elgibile countries.
Once the travel pass period ends, if you continue using the services, you will be charged either the daily Easy Roam Intl if you have it added to the your service, or the pay per use rates, in case you don’t have Easy Roam Intl,
To use the data in roaming, you will also need your data roaming turned on in the phone settings.
Here are some helpful links https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes
  • Jul 30, 2025 2:05 PM UTC
Hi ​@Eva Schunicht
  • Jul 30, 2025 3:22 PM UTC
Just make sure Easy Roam is enabled on your line first (it should be by default anyways).  Then you can text the Easy Roam code.  I recommend doing this a day or 2 prior to leaving Canada.  When you land in Europe and use your phone, the Travel pass should work.
