Smart +
  • April 10, 2026
  • 1 reply
  • 16 views
To add the Smart + bundle , I would need to wait till the first of next month to cancel Netflix and Prime from my cable provider?
1 reply
  • April 10, 2026
You don't have to, but I would highly recommend that all you subscriptions are expired first. Then sign up for stream+.
This way if there are any issues or glitches it would be a cleaner fix
