Roaming quality/coverage - Portugal
  • Sep 18, 2024 3:48 PM UTC
  • 3 replies
  • 192 views
For anyone who has used Koodo roaming in Portugal - can you comment on the speed and coverage of cell service in the main tourist areas?
Best answer by Dennis
Yes it will.  Or you can manually select one of those carriers in your network settings
  • Sep 18, 2024 3:51 PM UTC
You can find the list of Roaming partners in the PDF in the link below.
https://assets.ctfassets.net/8cecwr1x4jkf/4LXFhimjwcok4pWRX7opfh/ec82c8c4d2d6347da76181f40e05c037/English_Coverage_Maps_Updated_2022_09_30.pdf
You can then google the carrier with the area you are visiting
  • Sep 18, 2024 4:13 PM UTC
Thanks - that’s helpful! It lists three carriers for Portugal. Would it just switch to whichever of the three has the strongest signal?
  • Sep 18, 2024 4:21 PM UTC
